Transom
searaynoob
Hey guys I have just picked up a 1977 Crestliner Apollo 660 and love the hull design and layout of the boat. I am planning on a transom redo because the old one is shot. Two questions though for all of you boat savy people, as I am still learning.
1. The boat is rated for a 115 but it has a 140 hp evinrude on it, previous owner installed a 1/2" steel plate both sides but the transom was rotten bottem edge.
2. In doing the transom I have planned on having a solid piece of white oak milled down to what I need that way I have a solid 1 3/4" piece instead of laminating two pieces together and white oak is tougher than s**t and is good around water. I have a friend that did it in his 19' crestliner and it is solid as a rock to this day. Just wanted to see if anyone else has done something similar. plus I figure that if I put the 140 back on which is highly likely as I don't have another motor the steel plate combined with the solid transom should do the trick. Any insight would be great!
Re: Transom
Ayuh,... After the transom is replaced, ya Won't need any steel plate, of any sort,....
'n White Oak is way overkill,... Doubled laminated 3/4" plywood is All ya need,...
searaynoob
Re: Transom
understandable I some what thought it was over kill but a friend has a mill and is willing to give me a solid piece of white oak milled to my specs so just wanted to make sure...because I don't want to be the guy that drops a 140 horse in the water!!! lol anyways thats good to know I will continue as planned and rip off back section of cap and start pulling the transom I am pumped to redo this boat...finally found a boat that I like and that is worth redoing! I think I am going to start a thread on my rebuild in case anyone else would want to redo a solid transom as I am doing. stay tuned!!!
jbcurt00
Re: Transom
If you want a solid transom, I'd suggest using SeaCast or similar. Not white oak, good around water or not.....
A 1 3/4" thick solid pc of oak will be very heavy & if it ever wants to twist or warp, it will likely best your efforts to stop it. Laminated in fiberglass or not...
I'd strongly suggest you take Bond-o's advice, double 3/4" plywood, well sealed & wrapped in fiberglass will serve you well. OR use the SeaCast.....
Woodonglass
Re: Transom
I totally agree with all the above. Oak is NOT the best choice for a transom Plywood is much more stable. Also for insurance purposes if you are over the Rated HP you insurance on the boat is usually null and void for any accidents.
searaynoob
Re: Transom
Yea I don't plan on having insurance on it other than maybe accident insurance if anything were to happen, boat isn't worth trying to get any money for it if I crash it. I will have to think about it because I am trying to stay on a budget on this restore and it was offered for free...he has had his transom in his crestliner for 10 years so far and takes it out to lake michigan and stores it in a pole barn in the winter and he has no issues so far...???
jbcurt00
Re: Transom
The insurance isn't 'just' to cover your boat's worth or repair.
Your boat, your friends & family, resto as you deem sufficient....
Maybe you are the only boater on the body of water you boat...
pckeen
Re: Transom
Hi Searay,
Solid wood versus Plywood for a Transom
I reccomend against using white oak for a transom. It will be weaker than a plywood transom. That's the short answer. Here is the long one.
Although an inch and a half thick piece of white oak will be very solid, solid woods are not dimensionally stable, as they expand and contract with the seasons. They will expand and contract most 'widthwise' or across the grain, with seasonal, heat, and humidity changes. In addition, unless you have quartersawn white oak, wooden boards have a tendency to bow or cup as they age. If woodworkers don't plan for this type of movement, the pieces of furniture they build will quite literally tear themselves apart. By way of example, take a look at the photograph below (of a table with pieces of wood oriented in different grain directions. This table's edge was originally flush. After one season, it moved out this far from each other. This tabletop was fully sealed with teak oil.
Plywood is substantially more dimensionally stable than solid wood. When plywood is constructed, each 'ply' (or thin sheet of wood), is oriented at 90 degrees to the ply next to it. The result is that as seasons change, wood movement in the individual plys is constrained - so it cannot move as easily. Plywood is much less likely to expand or contract or warp than a similar thickness of a solid wood. This is why, even in so called solid wood cabinetry - most cabinets are built of plywood.
In addition, plywood is substantially stronger than a similar thickness of solid hardwood. Ever seen a karate expert break a board? It's actually a fairly easy thing to do. What the expert is doing is hitting a solid wood board along the grain. The wood is quite weak in that direction, and will split easily. If you have ever split wood, you will know how easy it is to split a log along the grain with an axe...and how it is impossible to split a log across the grain.
So why is all this important for you?
I believe your boat is fiberglass. If it is, and you then seal the solid wood piece of oak in place, the wood will expand and contract with the seasons. Quite literally, what the transom will do over time is strain - pressing outwards, then pulling inwards against the fiberglass envelope around it, which will increase the risk of it cracking the transom. The wood will separate from the transom - creating a gap that could retain water. Second, the board will have a tendency to warp as it ages (particularly if water gets into it, for example through cracks in the fiberglass), which will have a similar effect. Third - remember the karate analogy? Think how much pressure is put on a transom by a motor. Cracking along the grain could occur. A piece of plywood will not similarly crack, unless it completely rots out.
For all these reasons, and if budget is a factor, you would be better off getting a sheet of exterior grade (not pressure treated) 3/4 inch plywood, and laminating two sheets of it together, to make your transom. Even in Canada, that type of plywood will only run about $35 a sheet. If you look on the threads in the restoration section, you will see lots of recommendations for plywood.
Now, although I'm recommending against it, I'm not telling you that the transom will wreck the boat - you may be just fine. If you do decide to use the oak, check a couple of things. First - confirm that the oak you are using has either been kiln dried or properly air dried (assuming the board is currently two inches thick - this would usually mean at least two years of air drying, before it can be used). To check that is has been properly air dried, you need a wood moisture meter, to check that the wood has dropped to a low enough moisture content. If it has not been properly dried, don't use it, as it will have a high moisture content, and will shed that, changing shape and dimensions considerably over the years. Never use green (freshly cut) wood, as it will warp and change shape considerably. A 12 inch wide piece of white oak will shrink by at least an inch as it dries. Second, even if it is dried, once your buddy has milled the board to final thickness and size, wait for at least two weeks (a month would be better), to see if it changes shape or warps. It is common for both air dried and kiln dried woods to warp after having been milled, because this process gives the wood another opportunity to lose or gain moisture.
Finally, I know that you will probably be sealing the wood - all I can say is while that will reduce the gain and loss of moisture from the wood, and will reduce the expansion and contraction that can occur, the wood will still expand and contract. Solid wood tabletops, even when completely sealed by a varnish or urethane will still expand and contract with the seasons.
Best of luck - and welcome to Iboats - I look forward to seeing your project come together.
