Tri-Hull Club...Yes? No? Maybe?
  • Total voters
    119
64osby
Re: Tri-Hull Club...Yes? No? Maybe?
I have to rescind my membership in the Tri hull Club. My Hurricane project is going, going,
gone.
I have become a Tinny.
The good news is the lucky buyer should soon be in the ranks here at iboats.
1973Chieftain
Whew, another complete convert to the non itchy light side of the Force :D Seriously, glassers sure cause one to itch when they are being cut up!
tallcanadian
Got my stickers today. Thanks again, they are awesome.
chiben123
I'm very curious how you put the fuel tank under the floor. My floor is stable so I haven't messed with it. Is there a standard floor pattern? I'd really like to extend the range of my boat.
dil
while I was replacing the floor, I cut out the ski storage and inner 2 stringer, then reenforced the outer stringers and added 2 more bulkheads as well as fiberglassing plywood to the inner bottom or the hull for extra support
chiben123
dil
while I was replacing the floor, I cut out the ski storage and inner 2 stringer, then reenforced the outer stringers and added 2 more bulkheads as well as fiberglassing plywood to the inner bottom or the hull for extra support, and i used a Moeller Marine Below Deck Permanent Fuel Tank (27-Gallon, 49" x 24.5" x 7.88")
BudL1te
I guess it would mean that I qualify.
tallcanadian
These stickers are awesome.
Looking better.
Doh! Looks even better.
southkogs
Tallcanadian, I am green with envy of your front toneau cover. That's made very nicely.
tallcanadian
It is nice. So is the rest of the top. I was very lucky to get it this nice. It's aged but still in very good condition. I've never had one before and I'm thankful I have it now.
southkogs
I used to have full running canvas for my Royal American, and when weather hit it was wonderful to have. We could keep cozy in some fairly inclement stuff.
My new(er) boat didn't come with the canvas. We wouldn't use it much (the Admiral doesn't do foul weather), but it'd be nice to have in my back pocket.
I'd like to join. I just picked up this 1972 Marlin Jupiter... my first boat!
Quick update: The two important repairs my boat needed was a new throttle cable (it was severed near the control unit) and the temp gauge repaired. My mechanic found the cable ($67), and the temp sensor unit ($140). I should have her back late this week. Then I'll post more pics and perhaps my own restore thread (?). -Paul
mcconnell63
Hi Guys, I couldn't find the place to start a new thread so I'm starting now. I'm looking at a Tri hull boat that is in the mid to late '70,s but it doesn't have T or T on it. The marine shop in town says he could get me a used one, what would be the best and $ wise way to go. Thanks for your help, Al
tallcanadian
Is T and T trim and tilt? Depending on the motor you can get a used one or you can look at getting a CMC power trim unit for around 600 dollars. Then you can put any motor you want on it.
srollin
Here's my trihull. Pondering on doing a full restore, what do you guys think?
From the back
Inside (needs a cleanup, I got stuck in mud at some point).
southkogs
Interior doesn't look too bad - I wonder if you could do a bunch of clean up, and buff/wet sand the hull?
