Trim adjustment
I have a 1994 Rinker Fiesta V 265 with a 7.4 Merc and Bravo II outdrive. I am wanting to adjust the trim sending unt so the gauge will more accurately show the correct position of the outdrive. I have noticed a round unit on the starboard side of the outdrive that I am thinking maybe the sending unit. Is it adjustable?? Thanks.
Re: Trim adjustment
The Alpha I drives had trim limit switch on one of the pivot pointso fhte OD, and trim sender on the other. Both had slots for to make the adjustments, after loosening the phillibs head screws.
Re: Trim adjustment
OK Lets try that again.
The Alpha I drives had trim limit switch on one of the pivot points of the OD, and trim sender on the other. Both had slots for to make the adjustments, after loosening the phillibs head screws.
CheapboatKev
Re: Trim adjustment
Welcome Aboard litehouse...
head on up to the first post in this forum and download your manual. There will be specific instructions on adjusting both units to get your gauge and od in sync..
