Trim Control
Sparke
I have a 1988 Celebrity with the 5.? V8 Merc drive. On the throttle control the trim switch use to have two options, one for trailering and one for motoring. Now it only works in the trailering position. This isnt a big deal since I can still raise the trim but it was nice so a person couldnt trim to high in the water. Do you think it is a bad switch in the handle? Or something else. I am new to your forum so I appolgize for anything I might have done wrong.:)
Re: Trim Control
It's probably a faulty trim limit switch.
Ayuh,... 'n it's mounted on the outdrive...
Sparke
Re: Trim Control
Thank you I will get right on it.
NHGuy
Re: Trim Control
At least try to adjust the sender before you even think about changing it.
