Trim Cylinder Anodes
NateCCIE
My 93 Bravo One trim cylinders don't have anodes on them. I bought a anode kit to put some andodes trim cylinders. It seems as though they screw onto the endcaps but I don't have anything for the screws to go into. Is there some kind of threaded insert I can put in there to be able to install these anodes?<br /><br />Thanks<br />-Nate
Re: Trim Cylinder Anodes
Nope, no inserts.<br />You could by new cylinders :rolleyes:
NateCCIE
Did they not always have trim cylinder anodes?
crazy charlie
You can put 3/4 in collar zincs on the end of the cylinder arms.They are way beefier than what you are trying to use anyway.Charlie
NateCCIE
TilliamWe,<br /><br />What do the threaded ones look like?<br /><br />I also have 4 holes but they are all not threaded. I am wondering if the threaded inserts fell out?
TilliamWe
Banned
Originally posted by NateCCIE:<br /> Did they not always have trim cylinder anodes?
MAybe moons and moons ago, but every Merc outdrive I have ever seen has had anodes on the trim cylinders. My 1997 Bravo series has four holes in the end of the trim cylinder. Two are just blanks, and two are threaded.
TilliamWe
Banned
I don't think they are inserts. In your case, they may just be really really dirty? I belive the threaded holes to be at 12 o'clock and 6 o'clock.
elpaso
You can put 3/4 in collar zincs on the end of the cylinder arms.They are way beefier than what you are trying to use anyway.Charlie<br /><br />Charleys correct - this is all the had up to<br />about 1992 - if you rebuild your cylinders -<br />the new end caps will have the new style 4 holes.
crazy charlie
Dont really need a part #.Any marine store will have a section for zincs.They are universal.Charlie
elpaso
The 2 blank holes in the end cap.<br /><br />A pin type spanner tool fits the holes <br />for removal on cap.
