Trim Cylinder Cap Seals
AndyD
Does anyone know where to obtain trim cap wiper seals for a 99 150 Johnson. It seems everyone wants to sell me a complete overhaul kit when all I need are a couple of wiper seals which are cracked and split. I have no leaks (yet). I figure that replacing these now will prevent future problems. I'd probably also replace the cap o-rings while it's apart.
Re: Trim Cylinder Cap Seals
The entire rubber seal set is only $50. Why not buy it and replace the ones that leak now. You will then have parts for the future leaks.
I have found that when the wipers need replacemnt, just putting in new orings only helped for a short while.
