Trim Guage
moderator1
ojgmal1 <br />First Mate <br />Member # 30407 <br /><br /> posted August 08, 2003 08:34 PM <br />--------------------------------------------------------------------------------<br />Forgive me for tagging a question onto you, but maybe whoever answers your question can do mine as well. I have a 91 Caravelle nad trim guage does not work (or doesn't seem to work) regardless of trim angle. were is the sender on hte outdrive so I can check to see if it is connected? <br />--------------------------------------------------------------------------------<br />Posts: 1 | From: alabama | Registered: Aug 2003 | IP: Logged
Re: Trim Guage
Well moderator1 + ojgmal1 ( I Think ??),<br />The trim Sender,+ the trim Limit Switch, are located on(over) the pivit pin on the gimbal ring......<br />1 on each side......<br />Good Luck... The work involved in replacing a broken wire is Not worth the Heartache.... <br />Learn to "Know" where your outdrive Is...<br /><br />You can Fix it the Next time you are changing the Bellows on your outdrive, You'll be going the next step Deeper into the transom assembley to change the wires....<br /><br />That Is, If your running a Mercruiser.....<br />Neither of you mention this....
ojgmal1
Re: Trim Guage
Thanks for the quick response. sorry I am new to I/O boating. I have a 135 hp '91 mercrusier.
