Trim motor
Wbassemier
My trim motor will go up but not down, its on a 175 mariner. Can i get it rebuilt or have to buy a new one if so how much do they cost?
Re: Trim motor
What year is that motor? Does it have two solenoids or two relays. It could be something as simple as a bad solenoid or relay, or a wiring issue.
Re: Trim motor
OK, Why not switch the two wires (blue, green) on the solenoids? If the behavior is the same the motor may be bad. If the behavior is opposite, the solenoid or wiring is bad.
