Trim not working??
gtfireftr
So I decided to trailer up to paint the outdrives etc. trailered up slowly... I then put them down...
Now I have nothing... will not trailer up.... will not even move at all.... I can get one click from the stbd drive, but nothing from the other, and after one click there is nothing.... Has anyone seen anything like this... Is there a fuse or breaker related to the trim pumps.... I find it difficult to believe that both pumps went out at the same time...
I appreciate any help.... TIA
kenny nunez
It may be a grounding problem, look at all the ground connections. Also if you have 1 main battery switch that could also cause the same problem. Are all of the batteries charged?
gtfireftr
Boy you guys are unbelievable....... Stbd battery was down to 9v.....Evidently that is the battery that runs the trim.... Thanks so much..... Awesome....
