Trim pump seal
77 1150. Short of getting a full rebuild kit for a trim pump that works great, what would you use to replace a reservoir seal? A big o-ring? Rtv cement? Something else? I’ve had to refill mine a few times this year already.
What part leaks? There is a large Oring around the pump/reservoir seam, and 4 orings in the control valve to pump seam.
