Trim pump tread size
gabe1
Hi
1989 mercruiser trim pump
Anyone knows the tread size for taping the in and out oil connector on the trim pump?
Bt Doctur
Re: Trim pump tread size
If your pump has the brass fittings the the hoses go into ,then it`s called :eek:ne eighth pipe tap (1/8 NPT).The pump body itself: replacement.
gabe1
BT thanks for your reply
No brass fitting
The original trim hose connects directly into original pump body.
Let me see if I understand you correctly.
Taping the body of the pump is not possible?
Gabriel
Bt Doctur
No, because the fittings are not a straight thread, The end of the fitting mates to a lip for sealing similiar to hyd. fittings.
