Trim rod seal replacement 99 Ocean Pro 200
jlemberg
It looks like one of my trim cylinders is leaking. How difficult is it to do?
boobie
Re: Trim rod seal replacement 99 Ocean Pro 200
Seeing where you're from you'll probably need the OMC special tool and some heat to get the cap off to get at the seals. You can buy a spanner wrench and that may work. Once you get the cap off it's pretty easy to replace the seals.
Haffiman
Trim up the engine and 'lock' and secure it in tilted position.
Open the manual release valve to remove internal pressure.
Unscrew the trim cylinder cap. NB: Use correct tool!!!!!
Change seal and re-install.
Refill oil if needed.
Quite an easy task.
Tilt cylinder however is a bit more tricky as the big top bolt has to be removed first.
jlemberg
Doesnt sound too bad, where do you get that cap spanner tool?
boobie
Most parts houses, Snap-on or Mac tools. Sears may even have them.
I made a spanner out of two pieces of angle iron and three bolts. The bolts need to just fit the holes in the cap. Use some penetrating oil to help it get loose.
boobie
If you have a shop with all the right equipment it's easy to do. I've made a lot " Special Tools " over the years when I didn't have the correct one. Nothing wrong with it.
jlemberg
I'm going to give it a shot....here are the parts I think I'll need. Please correct me if I'm wrong:
0435345 TRIM ROD END CAP & SEAL Assy
0337496 THRUST PAD - Do I need this only if the old one is damaged?
Maybe you only need the rubber seal kit, for that PTT unit. It will run about $50, and have all the Orings and the wipers for the trim rod caps.
jlemberg
Yes that would be nice as the cap is $130...I didnt see it as a separate part #. I'll call the parts supplier. Many thanks.
jlemberg
Yep its part 0434519 O-ring and seal kit. Has the complete gasket set for the whole system, thats what confused me.
