trim sending units
gostephen
i just replaced my gimble housing
when i took the trim sending units off i forgot to note which one went on the starbord and which went on the port side
can some one tell me which side the trim position and trim limit senders go on
Limit on port and sender on starboard. there is also a mark on the back side where you align the sender pivot prior to installation so you can adjust it as needed.
MarkSee
Here's the adjusting instructions if you don't have them.
Mark
  • Trim limit switch install instructions.pdf
