Trim Tabs leaking Tranny Fluid?
gstanton
1995 Sea Ray 230 DA, I/O, purchased used 5-6 years ago, with Bennett Trim Tabs. I recently noticed upon returning from a day trip, while flushing the engine on our lift, that there was a small amount of pink (ATF?) fluid coming out of the base of the port side trim cylinder. I would approximate that it was much less <br />than a half teaspoon... barely noticeable. On the other hand, I've never noticed it before. Am I seeing the beginnings of a problem? I felt the base of the starboard side and there was a drip of fluid present there also. I had just had both tabs<br />fully extended while we idled into our canal (for improved steering control) and when we are under way typically have to engage the starboard side switch (port side<br />cylinder) slightly to trim the boat. We winter here in salty FL and lift the boat out every time. In summer the boat is docked in fresh water 24/7. I've never added ATF.<br /><br />If this is a developing problem, can I simply replace an O-ring on the piston or replace the piston itself, or need I replace the entire cylinder assembly? Any advice is appreciated!
ed/il
Re: Trim Tabs leaking Tranny Fluid?
You can replace the o ring / seal. Go to the Bennett web site and they will help. If it is not to old the parts will be free.
crazy charlie
You should surely replace the orings.Not difficult to do.There is a Bennett trim tab employee right here on this site.He emailed me the exact way to do it and even gave me his cell # if I got stuck.Try a call for Tabman.I think that was his name.
QC
Careful though, you don't know if the O-ring is your problem . . . It could be where the nipple threads into the upper mounting plate etc. If your boat is at home and/or easily accesible, try looking over the parts etc. If it is more remote, I'd buy a complete cylinder and swap it. They come with replacement destructions which are slightly different than new install destructions if I remember correctly.
gstanton
I sent the same question to Bennett Trim Tabs and here is the return response:<br />">Thank you for contacting us with your trouble.<br />><br />>Yes, we have seal kits that can be sent out to you at No Charge, but I <br />>will need your mailing address to do this for you. Please keep in mind that<br />the actuator will have to be out of the water to make this replacement and you should<br />wait for them to arrive, since they come with installation instructions too!"<br />><br />I certainly never expected this kind of response! It is unusual to find a company that will back it's product even after the warranty period has expired. Bennett Trim Tabs has made a believer out of me!
QC
Yup. They bought and sent stuff to me too after it was well out of warranty. I simply emailed for diagnostic assistance and they just offered to send me the failed relay switch thing for nuttin'
