hi, where is the fluid cap for my 1987 125hp trim/tilt
H hays Cadet Joined Aug 1, 2012 Messages 8 Aug 1, 2012 #1 hi, where is the fluid cap for my 1987 125hp trim/tilt
F foodfisher Captain Joined Feb 18, 2009 Messages 3,756 Aug 1, 2012 #2 Re: trim/tilt 1987 force help locate fluid cap Below the motor, on the pump body (you can see the division) is a ferreled plug/cap. That's the fill..
jerryjerry05 Supreme Mariner Joined May 7, 2008 Messages 18,196 Aug 2, 2012 #3 Re: trim/tilt 1987 force help locate fluid cap Screw /cap on the side of the pump housing.
H hays Cadet Joined Aug 1, 2012 Messages 8 Aug 3, 2012 #4 Re: trim/tilt 1987 force help locate fluid cap Thanks man. I had so much paint on the pump it looked like a pimple under skin. Thanks again.
