Trim
Lawnpro979
Finley took the boat out today, V6 3.4
trim was working fine then it stopped working. Returned home messed with it a little, my son had his finger on it going up and down, I played with the relays pushing down left and right as much as I could, the trim would work for a sec or two then quit again.....I could only feel one of them clicking.. does this mean it’s a bad relay???
Since neither are working very well it would be electrical. In most cases its connections or the throttle handle switch.
Need to use a voltmeter and trace voltage, and clean connections
