Trolling motor shaft support.
Skipb48
How important is it to support the trolling motor shaft when the trolling motor is stowed while on the trailer? Has anybody had problems with the shaft bending while trailering?
eggs712
I added a stay/shaft support to mine after hearing stories of trolling motors breaking off at the mount and/or damaging the fiberglass from choppy seas. It also helps on bumpy roads when trailered.
Often thought about adding a support but never have damaged one.....yet..!
Mine has the carbon fiber shaft with the supposed lifetime warranty against breakage.
cyclops222
IT is supposed to lay on the deck. A piece of CLOSED CELL rubber mat about 1" is ok to prevent marking the boat deck.
Skipb48
Thanks for your responses. Mine is a Minn Kota Terrova Quest and the shaft seems pretty durable. The way it is stowed puts it about a foot above the floor, and just inside the gunnel. I don't usually run the boat fast enough in waves that the boat slams up and down, so I'm most concerned about towing and hitting bumps and potholes.
I’ve got one on my Garmin force. Those things bounce around more than you think. Cheap insurance.
