trouble opening zip files from adults only section
stevenj
I have sent a p.m. to ken_23434 that I cannot open the downloaded mercruiser 10 files, the zip folder comes up with an error of corrupted file.
did anyone else experience this and if so how did you open it if you were able to.
steve
Bt Doctur
Re: trouble opening zip files from adults only section
what manual number
stevenj
what manual number
Bt doctur manual 10 which if I read right should cover the 3.0 litre G.M. 1987
which is what year I have.
YOu should have tried the link just above the one you are trying to use.
Looks like this.
attachment.php
stevenj
Thanks Don, worked great, For some reason I didn't even try that one, tunnel vision I guess.
Steve
