trying to figure out what outdrive
m283mark
I just bought a 1984 Rinker w/ the 3.7 188 the whole out unit was stolen I'm trying to figure out what is suposed to be on it he thinks it was alpha gen 2 does that sound right. my next question, I have pre-alpha unit i had off another boat that went bye bye. would this work at all every thing seems to be same to mount and shift i know the gear ratio is slower but just plan on fishing for now + just want to check every thing else out. He says it ran great i did read the problems w/the 3.7 oil looks clear and i dont see no streaming from timing cover.
IVAZ
Re: trying to figure out what outdrive
Gen 2 did not come out until 1992 so I doubt thats what came with it. Im not 100% sure but I dont think a pre-alpha will bolt up. I think you need a gen 1.
Ayuh,.... It'll bolt on,+ Work,.... Except for the Ratio part...All else is the Same...
IVAZ
You can bet this guy is right and I was wrong.:redface:
m283mark
you just gave me the goose bumps great!!!!:D
Ayuh,...
Basically,.... The Mod. 1s, the R, the MR,+ the Alpha 1 are interchangable between each other...
But,...
There Are exceptions..... ;)
