Turning Point props
shadowdwpp
I was boating today and hit a a partially submerged log with 20 inch diameter. It didn't do any damage but I decided to call it a day as there was an unusually high amount of debris in the water due to resent flooding in the area.<br /><br />while going back to the ramp I hit another log this one spun my hub. can I get a new rubber brushing installed or should I just get a new hub for the prop.
rickdb1boat
Re: Turning Point props
You are talking about a new housing for the prop. I would at least have it repaired and use it for a spare prop if you decide to get a new prop...
If it was a turning point prop just replace the hub! It did it's job.<br /><br />Bob
