type 1 need bolts
mahend
i have a 70 type 1 mercruiser that i am rebuilding serial number 29607... i need the 2 studs that come out of the back of gimble housing and go through transome as well as the other 4 that get the anode caps any idea of part numbers or where i can find? mine have corrosion and have been eaten way some
Re: type 1 need bolts
Ayuh,.... Those are Oem, Mercruiser parts....
mahend
can i get them from iboats .... i cant seam to find them
Nope,... Because they're Oem, Mercruiser parts.....
Not available aftermarket...
mahend
ktbarrentine..... thanks that is what i need , not cheap though i will use the part numbers and see if i have them local
