Type of oil to use...recently bought it
ceasarea
I am in Ontario....Generally run the boat May 01 to Oct 01.....so the temperature is always above 18 or so...or lets say high 60's...I am having it winterized and bought synthetic 5w20...Is that ok for my 1997 4.3gl Volvo out drive....Thanks
Re: Type of oil to use...recently bought it
I am not sure what Volvo recommends, but you should find out and use it. My 4.3LX MerCruiser specified special motor oil. Currently it is FC-W oil. Some years ago it was Quicksilver 25W40 oil or SAE 30 or SAE 40. It was never automotive multi-viscosity oil. From what I have been told, automotive multi-vis oil does not have the heavy duty lubrication properties necessary for a marine engine under typical load.
HT32BSX115
Take a look at page 79. It says to use 20W/50 with a service rating of SG.
DLH
http://www.appletonpier.com/auctionsourcedotnet/boat/volvo penta marine engine owners manual.pdf
Yeah.....do not get too "wrapped around the axle" trying to find API SG oil.
It doesn't exist anymore. It's an obsolete specification.
http://www.api.org/certification-programs/engine-oil-diesel-exhaust-fluid/~/media/Files/Certification/Engine-Oil-Diesel/Publications/MOM_GUIDE_ENGLISH_2013.pdf
Volvo recommends using their own oil: API SM, SAE 5W-30
OR their own branded synthetic Viscosity: SAE 15W-50/SAE 30
Grade: API SJ, ACEA A3/B3
for all the below model engines.
230A, 230B, 250A, 250B, 251A, 3.0GLM-A, 3.0GLM-B, 3.0GLM-C, 3.0GLMMDA, 3.0GLP-A, 3.0GLP-B, 3.0GLP-C, 3.0GLP-D, 3.0GLP-E, 3.0GLP-J, 3.0GLP-N, 3.0GSM-A, 3.0GSM-B, 3.0GSMBYCCE, 3.0GSMBYMCE, 3.0GSM-C, 3.0GSMEFS, 3.0GSMHUB, 3.0GSMLKD, 3.0GSMNCA, 3.0GSMNCS, 3.0GSMWTR, 3.0GSP-A, 3.0GSP-B, 3.0GSPBYCCE, 3.0GSPBYMCE, 3.0GSP-C, 3.0GSPEFS, 3.0GSPHUB, 3.0GSPLKD, 3.0GSPMDA, 3.0GSPNCA, 3.0GSPNCS, 3.0GSPWTR, 3.0GXiC-J, 3.0GXi-J, 4.3GIPBYCCE, 4.3GIPEFS, 4.3GIPHUSCE, 4.3GIPLKDCE, 4.3GIPNCBCE, 4.3GIPNCMCE, 4.3GIPWTC, 4.3GIPWTR, 4.3GL-A, 4.3GL-B, 4.3GL-C, 4.3GL-D, 4.3GL-E, 4.3GL-EF, 4.3GL-G, 4.3GL-GF, 4.3GL-J, 4.3GL-JF, 4.3GLMMDA, 4.3GLPBYC, 4.3GLPEFS, 4.3GLPHUB, 4.3GLPLKD, 4.3GLPMDA, 4.3GLPNCA, 4.3GLPNCB, 4.3GLPNCS, 4.3GLPWTC, 4.3GLPWTR, 4.3GSPBYC, 4.3GSPHUS, 4.3GSPLKD, 4.3GSPMDA, 4.3GSPNCB, 4.3GSPNCM, 4.3GSPWTC, 4.3GSPWTR , 4.3GXi-A, 4.3GXi-B, 4.3GXi-BF, 4.3GXi-C, 4.3GXi-CF, 4.3GXi-D, 4.3GXi-DF, 4.3GXi-E, 4.3GXi-EF, 4.3GXiE-M, 4.3GXiE-MF, 4.3GXiE-P, 4.3GXi-F, 4.3GXi-FF, 4.3GXi-G, 4.3GXi-GF, 4.3GXi-J, 4.3GXi-JF, 4.3GXi-P, 4.3OSi-B, 4.3OSi-BF, 4.3OSi-C, 4.3OSi-CF, 4.3OSi-D, 4.3OSi-DF, 4.3OSi-E, 4.3OSi-EF, 4.3OSi-F, 4.3OSi-FF, 4.3OSi-G, 4.3OSi-GF, 4.3OSi-J, 4.3OSi-JF, -----------------snip
You can view the entire list at Volvo Penta - Accessory Catalogue
You can get there by clicking Do it yourself - Do it yourself : Volvo Penta
HT32BSX115
Just to be clear....you are asking about about engine oil and not drive lube correct?
The Volvo link above delineates between engines and drives. (and some Volvo drives USE ENGINE OIL btw)
skydiveD30571
Correct and I am aware of that, but I just wanted to make sure what the OP was asking for because his wording makes it just a little confusing. He can find answers to both at the link you provided, but I just wanted to clarify for other readers. I could see someone reading that as "what oil for my outdrive" followed by answers with engine oil which isn't necessarily correct.
