Unable to access mercrusier service manual 1 for trim mtr wiring
michaelbluewolf
I seem to be having trouble getting access to the site Mercrusier 1 manual to gain the wiring diagram for my 1970s Mercruiser Prestolite trim motor on my 1970 Sea Ray. I have tried many times and the site will not respond.
Anyone have any ideas????
Thanks as always for the help.
Mike
Re: Unable to access mercrusier service manual 1 for trim mtr wiring
What site are you trying to access?
Mike
Ayuh,... Look at the links in this thread,...
michaelbluewolf
Thanks, Bondo
My 1970 Sea Ray has the early tilt/trim set-up with a prestolite pump and a single solenoid mount on the pump. The 1989 system is different so the wiring is different.
But, Thanks for responding, Mike
Sawz
Michael, I tried the link you showed and it was a no go also, but when I went to bondos link and scrolled down and tried his it worked strange if they are the same
