unable to move the prop shaft a bit in/out
adg
Hello,
On my Johnson 250 '94 I used to be able to move the prop shaft a bit in and out (possibly 1-1,5 mm or so) but now after I have resealed the prop shaft housing and re-mounted it I seem not to be able to do so any more. Have I tightened the housing to much or is that not possible? Is it normal not to be able to move the prop shaft a bit in and out? I have the housing with 2 retainers.
thx for help.
F_R
Re: unable to move the prop shaft a bit in/out
Shift rod adjustment???? See if you have movement in another gear.
boobie
Whack the end of the prop shaft once with a block of wood and a hammer and see what happens.
adg
boobie: I did as you said and now I have approx. just short of 1 mm shaft play (I guess). how much should I have, or is this enough?
would you be willing to explain how this one wack can give me more shaft play?
adg
thx F_R - thanks for input - I tried the wack as suggested by boobie - and that seemed to work.
Maybe it put the front bearing housing home.
boobie
All the whack does is seat everything in the gear case. You should be fine now.
adg
thx again for good advice boogie - learned a lot this winter/spring during this serviceing my motor.
