Uniflite hin
Notsosalty_yet
I recently purchased a 1975 uniflite. I purchased from an online auction without seeing the boat in person because it was cheap. The add said it is 1975 uniflite 31. The hin is UNF040820175. Hoping someone could tell me the model nu
sorry but model is not identified in a hin
If there was any company records that linked a hin or serial number, to a model number, they were most likely lost in the fire back in 1980.
Photos and measurements would possible help someone make an id for you.
Comogene
Uniflite's HIN, if there is one as early ones did not, do not generally indicate a "model". More often than not, there were only one or two models from any hull mold.
However, the photo appears to be a hull from the late 1960s. The configuration was simply called a "cruiser" and they made them in 27', 31' and 36' as well as a "sportfisherman" at 34'.
You might check the Uniworld site for more information.
