Update on 85 hp force L drive
Wrenchjunkie
Well So far so good gentlemen. Thanks to your help and direction I am making some progress.
Have a manual on the way (the clymer one ) got new plugs, found a brush set for the starter (old brushes were shot But with some tinkering I got em to work for a little while) Got the wiring fixed. Power tilt/trim works well, Engine spins with what seems to be good compression on all cylinders. Draining the fuel tank
dang thing was Brim full. Thinking I should pull the carbs and give them a good cleaning while i Got things dismantled. Need to get an impeller kit yet.
So far so good I will keep you all updated.
WJ
Re: Update on 85 hp force L drive
keeping my fingers crossed for you.
gregmsr
"Wrenchjunkie", I bet a dollar he can succeed!!
maxum247
Sounds like it's coming along! I get to do the carb once over myself this weekend. Good Luck!
maxum247
I built an L-Drive if you will from an old outboard lower unit and a 12hp riding lawn mower engine.
Guy down the street deals with Force outboards and such has an old L-Drive Force out there. Think it's a Bayliner open bow, I want it. Why it's different! Could probably get it cheap!
What's the latest? I'm interested in this one!
Wrenchjunkie
Well some more good news pulled the carbs and they are all 3 in excellent shape
no nasty buildup or gas shellac. it's lookin good.
WJ
maxum247
Clean carbs? Where? I need some of that luck!
I find myself putting my carb rebuilds off. I had planned to do them this weekend but just feeling kind of lazy after working all week!
Oh well! If I get them done too quick I'll be looking something else to do!
steelespike
I suppose these L drives will be collectable some day.
Check the value of a 58 Edsel Citation convertable today.
Or any of the Corvairs, or maybe even the VW 21 window micro bus.
