Upgrading Steering
DrEvil
I have a Mercruiser 140hp with 1st Gen Alpha 1 and I am looking to upgrade the rotory ride guide steering. Really, I just need the cable but I can't find anything that will point me to a replacement cable (Short of paying the dealer or finding a used one on eGay)
Is there a replacement teleflex cable I can buy here on iBoats that will work with the Merc setup?
Thanks
Vinny
JustJason
Re: Upgrading Steering
the steering boxes wear out right along with the cable. The gears are typically just pot metal. The manufactorers want you to replace the cable and box as a set and that's why you are having a hard time finding one. If you did just replace the cable you more than likely would still have sloppy steering.
BTW welcome to iboats.
DrEvil
Yeah I had the box apart yesterday. Everything works fine until I mount the helm and it gets real stiff. So I am almost positive it is a cable issue, but I wont be sure until I get a replacement.
I just adapted my new steering wheel to use the Merc system too... Now it looks like it is back to the drawing board once I upgrade to the teleflex system.
