Upper Pin on Gimbal won't come out
PX4855
Hey Guys, I have the upper pin on my gimbal giving me a problem. Any advice on persuading it to come out? Kind of at a loss on this... It's all I have left to pull to get the gimbal out. Hoping I can get this done before the weekend gets here!
stonyloam
Re: Upper Pin on Gimbal won't come out
Removing the gimbal ring right? I assume you removed the nut on top and the clamping bolt for the steering arm. I think that upper swivel shaft has a threaded hole in it and you can screw a long bolt into and use a slide hammer. I used a bolt through a hole in a board, then used a hammer to drive the bolt down. I am not too familiar with one that old.
Bt Doctur
You dont need to remove anything but the drive to get the gimbal "bearing" out
Bt Doctur
unless you mean this pin.
PX4855
Yeah, it's the pin pictured. Got it out per stonyloams instructions. Worked like a charm! Now to get it all put back together! Thanks for the help!
