Upper Shift Shaft Leak? Its normal? Pics and Video
krakatoa
Hello Guys Guys!
Just checking my lower unit yesterday and found this "stream" coming out from the upper shift shaft or "shoe". Can anyone tell me if this is normal or what part or o-ring have to be changed? First time I seen something like this one on my 2nd In/Out engine. Im more like outboards than in/out.
Need to admit that I change the impeller kit last week but fully forget to change the o-ring of the carrier assembly, the one below the impeller ...... bummer
Any info as always appreciate it
BIG THANKS
Bt Doctur
That does not seem normal going by the GEN II`s I have serviced.Should be a seal in that area
krakatoa
nothing wrong with it. Just went to my backyard and look my other spare gimbal and that drain hole is just in front of the exhaust bellow. look the pictures. So Im think we are good here...
Inside of the Gimbal, pointing with a SS cable
Front area
krakatoa
Nothing to be serviced or worried about. Case closed
