Use different plugs rather then RV15YC4 Champions
kylejb2663
I am replacing my plugs on two motors.. 1987 OMC Chevy 5.0..
Manual calls for RV15YC4 Champion plugs... I have heard horror stories of Champion plugs. Anyone have recommendations of what I should use or if those are the only plugs I can use to get the best spark and fuel economy?
Thanks!
Re: Use different plugs rather then RV15YC4 Champions
Thanks!
Ayuh,... The AC Delco, MR43T has been the standard plug for marine SBCs since dirt was invented...
NGK's
kylejb2663
Thanks Bond-o! I ordered them! The carbs have been loading up the engine so I figured since I ordered new carbs I better change the plugs... Anything else you think I should check or replace?
Ayuh,... How 'bout a Full tune up, service, 'n compression test,..??...
Ain't that motor Points fired,..?? changin' points is an annual event...
sstone
Replaced the 90 hours, very clean champions with ac delco, and noticed a much smoother idle. Haven't got to test mileage or anything. May have been inconsistent Gapping in the old plugs, or some other factor though
