- Joined
- Sep 26, 2009
- Messages
- 20,449
As a mechanic I can tell you using 4lo and damaging your truck all depends on you and the conditions. Yes, you will gain more torque to the wheels AND better throttle control. It will also be easier on your torque converter and transmission. The downside is it IS NOT meant to be used on hard, dry surfaces. Any amount of steering will put stress on everything from your transfer case to the front tires. Ball joints, CV shafts, tie rod ends, wheel bearings, control arms, front hubs.... everything. It's not my truck so I won't say what you should do, but if you feel the need to use 4lo to get up the ramp or like the finer control by all means use it. Just do your truck a favor and as soon as you are at the top of the ramp get it out of 4wd before you do any steering.
Couldn't agree more and the only exception to turning is there's gravel at the top of the ramp/parking.
