Using The Works To Clean My Engine Block
gungalunge
I got my engine block sitting here all bored out ready for pistons. I noticed that a build up of sand and dirt was caked on my water jackets . about 1/4 inch thick . got to be a cooling problem . so I used the works tolet cleaner . this is a blind hole bore 115 mercury engine1974 . so i splattered the tolet cleaner called the works all over the effeced caked areas . it started foaming stinking and turning all yellow . I let it set for 10 minutes and it cleaned all the way down to bare alimimum when i washed it off .. wow that was easy .
KCLOST
Re: Using The Works To Clean My Engine Block
I wouldn't use the works again on Aluminum!!!<br /><br />That foaming/reaction you saw was the aluminum being eaten away by the cleaner...<br /><br />Have you ever heard of a 2-liter bomb. They make them by putting small pieces of aluminum foil or an aluminum can in the bottom of a 2-liter bottle, then add a few squirts of the Works cleaner in the bottom. Put the cap on get out of the way. The cleaner starts eating away the aluminum and the reaction causing the 2-liter to blow up like a ballon until it explodes... <br /><br />What you did was eat away some of your water jacket, hopefully not too much you should check the gasket areas to make sure they were not degraded...
Twidget
Sounds like what we used to do with lye, water and aluminum as a kid. It makes a great hydrogen balloon, they go boom very loudly.
Clams Canino
Ya..... bad idea. I take to to the manual car wash and pressure wash the crap out of them.<br /><br />-W
Texasmark
Well gun, thanks for sharing your idea with us so that we might benefit from your experience.<br /><br />Seemed like a good idea to do what you did at the time; right?<br /><br />Well, thanks for thinking of us anyway.<br /><br />Mark
gungalunge
Hey it cleaned that caked on crap . It dont look damaged that I could see it just worked real fast.It cleaned it real well. I did not hear anything go BOOM but some chemestry was going on there it got stinkey .It was a quick 10 minute soak . Tex Your right .. Poor idea.I did have the pressure washer fired up for the rinse cycle .I yie yie .good thing i did not use it full strength .. it was a almost empty bottle that i filled with water ..
