V10 dodge truck. Any Good?
sod breaker
I have a chance to buy a 2001 Dodge 3500 4x2 dualy 12ft steel flat bed with 170k. It is a company truck and I been driving it for about a year now the company is upgrading to a 4x4. and offered the truck to me for $3000. Is it worth doing? Aside from being thirsty for fuel are the v10s good engines. This truck has been fleet maintained with reciepts for most the work done to it. I should also add that miles are hiway miles . truck is a 5speed manual. Truck was used to haul a trailer around about 7500lbs loaded and to run errands.
thanks EDIT P.S. I will probably be putting about 500 miles a month on this truck so fuel mileage is not realy a big concern to me
brian4321
I don't know a lot about them , but a friend of mine bought one several years ago and other than being a gas guzzler, he loves it and hasn't had any trouble to speak of
ezmobee
A running 3500 truck for $3k? I don't think you need to ask any further questions. Jump on it.
southkogs
I'm kinda' with EZ: you've been runnin' it and know it. For $3k? If ya' like it, it's probably worth it.
FWIW - I have an '04 2500 with a 5.7. Tough as nails rig. I love it. I've had several Dodges (2 cars, 1 minivan, 1 3/4 ton van and now this truck) and they've all been 250 - 300k mile cars/trucks.
it will pull ohio straight into iowa...... good truck, great price.
avenger79
you have some history with the truck so you know it a bit. you know it has had maint done properly
you won't find another running 3500 V10 truck for that price. go for it
angus63
My buddy has the same vehicle since new. He uses it to tow his antique vehicles in a closed trailer to shows all over the nation. Swears by it. If you have a use for it, I would invest in it. Worst case, you should get your money back easy if you sell it. Good Luck!
