V6 2 Stroke Idle problems
89Johnson225
Hi All,
I have an 89 Johnson 225 V6 that is having idle problems. I start it using the manual override on the primer solenoid (red lever perpendicular to the body of the solenoid) and it will idle ok, but it spits some un-burned fuel out the exhaust. When I move the red lever to the run position (parallel with the body of the solenoid) the motor coughs and chokes out. I'm not sure if it is a stuck reed or something else. I just rebuilt the fuel side of the VRO (not using the oil side, pre-mix in tank @ 50-1), and that is pumping well. Carbs were taken off over the winter and cleaned/rebuilt, new fuel lines from the tank to the carbs. Any ideas?
Faztbullet
Re: V6 2 Stroke Idle problems
88-91 has the crappest carbs for idle, unburnt fuel is ignition,compression or reed problems. I have seen several of the rubber coated reed block craked and peel on the se due to ethanol fuel.
Bosunsmate
id check spark and then go through the carbs again,
89Johnson225
Could this also be a timing issue? i.e. the spark advance set wrong (set at WOT timing at idle)?
