Vapor Lock or Choke Sticking??? 4.3 Merc
klaus96
89 Baja 190 Islander 4.3LX Alpha one....I have been trying to solve my "vapor lock" problem for a little bit and noticed something last weekend. I had been parked after running for a while so I had propped open the motor housing cover 6 inches or so while sitting. I went to leave and sure enough, crank crank crank...no start. Got nervous I would flood and be stranded so I removed the flame arrestor to look at carb. The choke butterfly was completely closed. I opened it and the motor started right up. Any thoughts?
mkast
Re: Vapor Lock or Choke Sticking??? 4.3 Merc
Do you know the operation of an engine utilizing a choke?
yep
figure out why the choke isn't opening
is it electric or mechanical??
Ayuh,... Which carb is on it,..??
klaus96
Still in shop. Shift bellows tore last week. I'll post back when I get it home and get the specs. I'll look at linkages also.
90stingray
I just wired mine open to avoid any issues. I never need the choke since its always 70 degrees plus when I go boating. Goodluck!
klaus96
Someone else told me to do that. Maybe I'll give it a shot. I only go when its warm too.
mtbr00x
I have the same problem, Mine starts up great every time I go out but if I stop and go for a swim or go to the gas dock I have a helluva time getting it started again. This only happens when the engine is warm. I have a electric choke. Someone told me my fuel is leaking down. What I have is a ford 460 with 2 holley 600's. Do ya'll think the bowls are leaking fuel or could this be a choke issue. Only one of the carbs has a choke and it does need the choke to start cold.
