VHF Radio Recommendations?
1970 Chieftain V
I am looking to buy a radio for offshore use. Probably between San Pedro, CA and Catalina Island about 22 miles or so. Do you guys have any suggestions? The one I am looking at right now is a Cobra MR F75.
Thanks
Jason
1970 Chieftain V
Re: VHF Radio Recommendations?
Thanks for the suggestion. That might be a bit more than I want to spend. What are some key features I should be looking for? I assume DSC is a must. Along with probably channel scan. Any other major feature the radio should have?
One more question. How do you match an antennae to the radio?
Jason
If the 504 is above your budget then look at the M304. The M304 has better performance specifications than the Cobra you asked a about.
eature wise, Send, Receive and class D DSC are the most important. Everything is just a bonus as far as I'm concerned. :D
Antenna wise, I can't put enough emphasis on the need of a good antenna. The antenna is the heart and soul of your VHF communications. Buy the best antenna you can afford then some.
The Shakespeare 5225-XT is the standard to which all others are held.
http://www.shakespeare-marine.com/antennas.asp?antenna=5225-XT
