VHS GPS accessory cable
tmcgarry
I have a West Marine vhs 650 radio. I’m looking for the accessory cable for gps position you plug into your gps unit. Anyone have any ideas. Thanks, Tom
Looks to be a discontinued part.
Time me to cut the connector off and go to discrete wiring
FWIW: the cable doesn’t connect to gps per say.
The cables plugs in to the connector on the radio to give you discrete wire to connect with the discrete wire connections from your gps.
