vibration at 2000-2500 rpm
rs1lollie
I have a vibration at 2000-2500 rpm trimmed all the way down, it smooths out over and under those rpm's, and when i full turn, i feel i also feel the vibration...
Boat is a 1998 Four Winns Horizon RS 180 Volvo 4.3gl with sx out drive.. wondering if its u-joints , gimbal bearing or prop...
This is best posted in the correct I/O forum. Likely U joints, but just a guess.
PatinIdaho
With out being there to check it out my bet would be Gimbal Bearing/U-Joints or a combo of the two.
rs1lollie
Any noises accompanying the vibration?
none that I hear, just vibration noise. I do hear some kind of faint knock every so often when at idle on the muffs. new jasper motor long block with about 10 hrs on it.
Augoose
Of course noises and vibrations are tough to explain, especially in writing and not in person. Who does your service? When was the outdrive last pulled and the gimbal and u-joints inspected?
