Vibrations when at idle?
jcac27
My boat vibrates pretty good when not moving. Prop is very dinged up, but that wouldnt cause this problem. Ive read taht this could be a bent prop shaft...<br /><br />Any ideas?
flashback
Re: Vibrations when at idle?
We need a little more info, make,model,drive etc.
jcac27
Oh sure forgot....<br /><br />1990 18 ft galaxy open bow<br />3.0L mercruiser w/ alpha 1 od
D
DJ
Guest
jcac,<br /><br />You bet a dinged up prop will cause that problem. I would fix the prop. before I started looking at a bent shaft.
jcac27
I just thought that the prop wasnt spinning at idle. I guess Im wrong and it is. When I say pretty dinged up, I mean really dinged up. The three tips of the blades are all bent back.<br /><br />Thanks,<br /><br />James
magster65
Does it shake at idle in gear or out of gear? In gear = what's already been said. If it's in neutral when it shakes it's probably time for a tune-up.
