vip vison problems
bossvip
89 vip 1750 2.3L omc and she back fires at times i give it full throttle and chugs, and she dies.
ive changed the plugs, wires, coil, timing, points and still does the same. i was told it could be the cam.
can you help me out or have any info that could
thanks
Re: vip vison problems
Hi. I can't help with your problem, but your thread title is confusing and will not get you the help you need. If a forum mod doesn't move this, I suggest you start a new thread in the OMC section.
frantically relaxing
Not confusing if you know what a VIP Vision is! (however, this IS a 'not engine topics' forum!)
thanks
Ayuh,.... It's goin' Lean,.... Change the fuel filters, 'n clean the rest of the fuel system,...
