volvo penta(1983) 270 od, dies at low speed
sdexcalibur
at low speeds my engine wants to die, I'm not talking about the warm up period, after say 3 hours on the water, when I'm going say 5 mph in the no wake zone, I hear and feel it going to die, I give it some gas and it's ok, I just got a new prop, don't have enough experiance to tell if it was from that, before I got the prop only went out 1 other time,
Re: volvo penta(1983) 270 od, dies at low speed
Ayuh,......
It sounds like your Carb could use some Attention......
Water in the fuel, filters need changing, tuneup needed, carb out of adjustment because it needs a tuneup.
Lots of standard ole preventive maintenance needs taken care of if you want it to run properly.
sdexcalibur
thanks for the advise, I did change the fuel filter, and oil filter, I was looking through my repair manual, and it looks like their is another inline fuel filter next to the carb. I don't know the exact model and the book has 4 different models, and ranges 1968-1991. The one I changed looked like the oil filter about the same size and shape, The one in the book, shows one in a hose.
Also how can I find out about if water is in the fuel? Thanks again everybody. for all the help and advise.
Steve
