Volvo Penta 3863330
Jrato14
Hello ,
I am in need of a replacement part for this ECM. Does anyone know if any parts have superseded this as it has been discontinued and very hard to find? Thank you for any help
He shows price of $3495
Ask if he can repair yours
What's the issue
Jrato14
Not enough voltage being sent to the fuel pump. And 5 volt reference
The 5V reference comes from the ECM but any one of the sensors that use the reference can cause the voltage to be low if they are pulling to much current.
Turn key ON and while measuring voltage disconnect each sensor one at a time and see if voltage comes back up
Low voltage at the fuel pump can be a bad connection or a bad pump. The ECM applies a ground to the FP relay and the relay supply's power to the pump
