volvo penta 5.0 alternator
mayjean123
on a volvo penta what should the voltage be coming out of l2 and if there is none what would cause to stop working
13.7-14.4 when charging. Battery voltage when not charging
Could be anything. What voltage do you have on the excite wire? If 0, you lost a diode or have a bad connection.
If you have batt voltage on the excite wite and its not charging, alt could need some love
Don't think you should get anything out of L2 because its for a light. If the regulator burns out then this point will turn on a light IF one is attached.
In my day, they had the lights on the dash of cars and we called them idiot lights. If they came on then this ment hey idiot something is wrong :D
