Volvo Penta Engine Repair Stand
Deepblue22
I have removed my engine, Volvo Penta 5.0 Gxi B(F), from the boat and it is sitting on wood blocks. My repair manual does not go into how to mount onto an engine stand. Do I remove the flywheel housing and then use the holes to mount to the engine stand? Any recommendation would be great. Photo attached.
Thank you.
GA_Boater
Take off the housing and the stand bolts to the motor using 4 or more of the flywheel cover bolt/holes. You may need to purchase some longer bolts.
Click image for larger version  Name:	estand.PNG Views:	1 Size:	269.3 KB ID:	10525353
Get the biggest engine stand you can afford. Stay away from cheep stands
