Volvo Penta wiring harness adaptor
Fun Times
Re: Volvo Penta wiring harness adaptor
You could try giving Warnerboats in So. Cal a call to see if they can help you out at (800) 515-5174. http://www.warnerboats.com/ Or I believe Iboats has it also, If so, I think i have it set up already in this link with the part number punched in so all you need to do is check out if you want to, And if the part number does not come up automatically when YOU open it, Then you might be able to punch in the part number [3884406] on you're end and place the order if you wish to. http://www.volvopentastore.com/Cart...--store_id.366--view_id.343833--viewcart.long Hope this helps, Good luck with it.
intrepidvoyager
Thanks boat tech ..... the VP number did the trick ...it's on its way
:D :D
