Volvo Steering Fluid vs ATF
GMTK
Got my steering arm/actuator removed and I'm probably going to send it off to be rebuilt, I'm about to get sent away for work again and don't have the time. The place I'm sending it to says to use "AW32 or AW46" for the power steering pump and system.
Two questions:
Do I need to fully drain the steering system now and if so how do I do that?
Can I mix the volvo trim/steering fluid that is in the system now with AW32/46?
Ayuh,..... It doesn't matter,..... All of the oils stated are completely compatible,....
I would use motor oil myself. SAE 30
