VP 3.0 stalling
Gopackgo2003
I have a 1995 VP 3.0gl that just started choking & stalling out today. This happens only when in gear and I try to accelerate. It fires right back up and rev's just fine if in neutral but when i put it back in gear it starts sputtering and will die if i give it too much gas. Any ideas what the problem could be?
Pull the carb and clean it. Most likely the accelerator pump circuit is plugged
Ayuh,..... Agreed,.... Crap in the fuel,....
