VP 4.3GL PEFS - S/N 4012018114
Symptoms - above 1500 rpm overheat, 1500 rpm and below fine.
Ran the checks from the VP Diagnostic Guide. This is what I found
Idle - Pressure 2psi but did not register a vacuum on the guage
1500 rpm - Pressure 8 - 9 psi vacuum needle flickering between 0 - 3hg.
At this time there was no bubbles in output and 2 large bubbles in input that didnt appear to move. No water was coming out of the hoses to the exhaust manifolds.
At 3000 rpm the pressure went to 20psi then dropped to between 10 - 5 psi flickering like mad input 0 - 3hg flickering. The output looked white with bubbles and input didnt seem to have bubbles. Tiny dribble of water down hoses to the exhaust manifolds.
So my thoughts are
a) I dont have a clue
b) Seal to the impeller bad, impeller bad.
c) Blockage in the block.
Q: I cant understand how I have high pressure on the output with no vacuum from input?
Q: Should the hoses to the exhaust manifold always be full of water?
Tried to get new impellor and seal but not in stock. Have ordered one. New thermostat installed.
Any thoughts?
Regards
Chris
So my thoughts are
Any thoughts?
Regards
Chris
