VRO pump differences
DirtinLa
Will a VRO that came off a 90 work on a 200... only need the fuel pump side NOT the oiler???
my model is j200stletf 93
and I'm looking at an 1986 90 hp working VRO
fhhuber
look at using the late 1970's early 1980's non-VRO pumps
You'll need to find and open the second crankcase impulse port for the second pump. Otherwise these should bolt right in and cost HALF buying a new VRO.
New pumps win.
The functional difference in the VRO pumps should mainly be in the alarm connection, which you won't be using if not using the oil side.
Not sure if there is a capacity difference in the 90 hp VRO vs the one off the 200. I would expect the 200 to NEED a bigger pump
Faztbullet
#2 Today, 07:59 AM
look at using the late 1970's early 1980's non-VRO pumps.You'll need to find and open the second crankcase impulse port for the second pump
Wont work on a looper... and the VRO difference is the glued on fuel fittings facing wrong direction. The newer OMS pumps have replaceable fittings.
