VRO Removal - 1985 Evinrude 110Is this the correct wire?
Old Irving
Hello,
Did I disconnect the correct wire bundle in order VRO wire.jpg to remove the VRO on my 1985 Evinrude 115? The group had 4 wires. The videos I watch disconnected two wires was that because they were two cylinder? I also removed the other connections related to the VRO.
Thanks,
Bob
flyingscott
There is only one set of wires to unplug. The wires you need come directly off the pump itself follow them to the plug and just unplug them. Then remove the tank wires
Old Irving
All the wires have been removed. Just wanted to make sure I disconnected the correct wires. Thanks.
